TVAR (Threshold VAR)
Postby EViews Gareth » Tue Oct 25, 2011 2:16 pm
This thread is about the TVAR Add-in that estimates a Threshold VAR using the R package tsDyn. You will need R to run this Add-in.
samijo
Re: TVAR (Threshold VAR)
Postby samijo » Wed Oct 26, 2011 3:15 am
Upon trying to add it, it gives an error that it's not available!
Postby EViews Gareth » Wed Oct 26, 2011 7:56 am
Sorry, try now.
Mihaain
Postby Mihaain » Tue Nov 01, 2011 9:39 am
I`m trying to estimate a TVAR model, but i get the following error: R(for 'test<-TVAR(g, 2, include="const"model="TAR",thhresh=1)') returned an error: evaluation stopped because of an error!
Any idea how to pass this error?
Thanks!
Postby EViews Gareth » Tue Nov 01, 2011 9:51 am
The R-code reported an error. Hard to know what that error is without seeing it.
gordeza
Postby gordeza » Mon Nov 07, 2011 7:28 am
Hi great people, I'm trying to run TVAR with the new add-in but keep seeing this error message "noexternal connection is open". I've R and I've tried to run tsDyn although I'm not s sure whether I've done the later right (I mean tsDyn).
Can anyone tell me what the above error mean and how to have tsDyn work (if that's the culprit as I suspect it to be)?
Thanks in advance.
Gore
Postby EViews Gareth » Mon Nov 07, 2011 7:50 am
Sounds like you haven't set up the R connection in EViews properly. Please see the EViews manual for more information on how to do so.
sweivE
Postby sweivE » Mon Nov 07, 2011 8:36 am
I got the same error like gordeza. I think its because the 'tvar' command cannot handle NA's as inputs. For instance, I tried to estimate a variable in log difference - dlog(gdp), and since the first observation of dlog is an NA it returns an error.
Try to change the sample accordingly and it might work
Question to Gareth - is it possible to get from 'TsDyn' St. dev of the coefficients? and IRFs?
Postby EViews Gareth » Mon Nov 07, 2011 8:47 am
NAs will not (at least shouldn't) cause an error of "noexternal connection is open". They will cause a separate error.
The R code doesn't have standard errors or IRFs :(
gordeza
Postby gordeza » Tue Nov 08, 2011 7:03 am
I've re-installed everything and now I keep getting the very same error message that Mihaain mentioned early:
"R(for 'testtar<-TVAR(g, 1, include="const"model="TAR",thhresh=1)') returned an error: evaluation stopped because of an error".
Any idea on how to proceed?
Btw, I've Eviews 7.2 running on Windows 7 Ultimate 64 bit.
Thanks in advance!
Postby EViews Gareth » Tue Nov 08, 2011 7:44 am
Could you post your workfile?
gordeza
Postby gordeza » Tue Nov 08, 2011 5:19 pm
Thanks in advance Gareth. Here is the file; which is the data from Tsay 1998 testing and modelling threshold models. I also hope the output displays the threshold.
testtvar.WF1
(10.95 KiB) Downloaded 2950 times
Postby EViews Gareth » Tue Nov 08, 2011 5:31 pm
I ran the Add-in with those two variables and it worked with 2, 3 and 4 lags.
gordeza
Postby gordeza » Wed Nov 09, 2011 5:11 am
Somehow it's finally working.
Thanks so much!
Scalper
Postby Scalper » Thu Nov 10, 2011 8:40 am
hello,
I've already installed the program R ,Eviews and its package as well the Add-ins TVAR. However, when i am put the variables and lags and when i click "ok" it shows up a error message " R is not installed, please check your eviews documentantion for instructions on installing in R"... but ive already installed.
Could you help me??
thanks
Yours sincerely,
Scalper
Return to “Add-in Support”
