Hello!
Could you help me how I can select a series from a a workfile on which a couple of tests could be run? There are several series in the workfile and after running the Eviews program it does every test on the first series in the workfile...
Many thanks!
Select command in Eviews
Re: Select command in Eviews
Double-click on the series of interest. It wll open up. You can then choose tests from the View menu.Hello!
Many thanks!
Hello!
I know that method! I would like to do the same in an Eviews program... Something like: "select gdp" where the name of the series in "gdp"...
You use the name of the series, followed by a dot, followed by the relevant command. For example,Hello!
gdp.histWho is online
