Select command in Eviews
lbkova
Postby lbkova » Wed Mar 04, 2009 7:42 am
Hello!
Could you help me how I can select a series from a a workfile on which a couple of tests could be run? There are several series in the workfile and after running the Eviews program it does every test on the first series in the workfile...
Many thanks!
Re: Select command in Eviews
Postby startz » Wed Mar 04, 2009 7:46 am
Hello!
Many thanks!
Double-click on the series of interest. It wll open up. You can then choose tests from the View menu.
lbkova
Postby lbkova » Wed Mar 04, 2009 7:54 am
Hello!
I know that method! I would like to do the same in an Eviews program... Something like: "select gdp" where the name of the series in "gdp"...
Postby startz » Wed Mar 04, 2009 8:05 am
Hello!
You use the name of the series, followed by a dot, followed by the relevant command. For example,
gdp.hist
