I am estimating several different VARs, and I need to combine one (or more) impulse responses from each VAR model into one single graph.
I'm sure there must be a simple way to do this - would be very grateful for help!
Best,
theeconomist
Impulses responses from many VARs in 1 graph
theeconomist
Re: Impulses responses from many VARs in 1 graph
Could you define what you mean by "one graph".
Do you mean multiple lines all on the same axis set, or multiple graphs all inside the same graph object?
theeconomist
Sorry, what I mean is: multiple graphs all inside the same graph object.
ok, create the multiple graphs as individual graph objects in your workfile, then select them all, right click on them and select Open.
theeconomist
