Impulses responses from many VARs in 1 graph
theeconomist
Postby theeconomist » Fri Feb 27, 2009 3:59 pm
I am estimating several different VARs, and I need to combine one (or more) impulse responses from each VAR model into one single graph.
I'm sure there must be a simple way to do this - would be very grateful for help!
Best,
theeconomist
Re: Impulses responses from many VARs in 1 graph
Postby EViews Gareth » Fri Feb 27, 2009 4:05 pm
Could you define what you mean by "one graph".
Do you mean multiple lines all on the same axis set, or multiple graphs all inside the same graph object?
theeconomist
Postby theeconomist » Fri Feb 27, 2009 4:21 pm
Sorry, what I mean is: multiple graphs all inside the same graph object.
Postby EViews Gareth » Fri Feb 27, 2009 4:34 pm
ok, create the multiple graphs as individual graph objects in your workfile, then select them all, right click on them and select Open.
theeconomist
Postby theeconomist » Fri Feb 27, 2009 4:44 pm
Thanks!
