Run Nonlinear Rolling Regression Code Need Help
roteirofigo
Postby roteirofigo » Wed Jul 20, 2011 10:17 am
I am running a complicated regression concerning ICAPM and using a MIDAS method to compute the weights to in calculating variance,the equations are attached in the word file:
The main regression is ICAPM:
Rt+1=μ+βVar(Rt+1)
and the tricky part is the way to compute Var(Rt+1)
I attached in the end.
It involves a rolling regression and I want to hold all the R-squares and find the coefficients with the highest fit.
How can I import such a complicated equation into Eviews and loop it to get the results?
Thank you guyz....
nonlinear rolling regression.docx
the regression equations
(21.59 KiB) Downloaded 543 times
roteirofigo
Re: Run Nonlinear Rolling Regression Code Need Help
Postby roteirofigo » Thu Jul 21, 2011 2:58 am
Can you help me Gareth...?
Postby EViews Gareth » Thu Jul 21, 2011 7:51 am
Not with the first part.
roteirofigo
Postby roteirofigo » Thu Jul 21, 2011 9:32 am
I know the first part is simple regression.
It's just the way to compute VARIANCE.
Can you help me with that?
roteirofigo
Postby roteirofigo » Sat Jul 23, 2011 4:52 am
No one can do that
