Panel HP filtering
naturama
Panel HP filtering
Postby naturama » Wed Feb 25, 2009 1:53 am
I HP filtered a panel with 21 nations. Then I unstacked the panel, I took the raw variables and I HP filtered the series one by one (I mean country by country). Surprisingly the filtered output is not the same, why? any hints?
Thanks for helping me.
Re: Panel HP filtering
Postby EViews Gareth » Wed Feb 25, 2009 9:03 am
Hi.
I'm sure I understand what you mean by this question. HP filtering is not allowed on panel workfiles (EViews will produce an error message stating this if you try it).
How did you perform the HP filtering?
naturama
Postby naturama » Thu Feb 26, 2009 1:08 pm
EViews 5
a) workfile with panel structure
b) open one series
c) Proc/HP Filter
d) you got the original series filtered
Thanks a lot for your prompt reply
Postby EViews Gareth » Thu Feb 26, 2009 1:19 pm
What is the build date of your copy of EViews 5?
(You can check this by clicking on Help->About EViews).
naturama
Postby naturama » Fri Feb 27, 2009 2:28 am
"Standard Edition - Aug 20 2004 build"
Postby EViews Gareth » Fri Feb 27, 2009 9:04 am
You're very out-of-date. You should update your copy.
fnarita
Postby fnarita » Mon Feb 11, 2013 12:46 pm
Hi all,
I would like to know any update available on this issue since EViews version 5.
I'm using EViews version 7.2, but having a trouble in HP-filtering using panel data.
My code is:
' Work on counry by country series temp = @crossid !ncross = @max(temp) delete temp for !i=1 to !ncross smpl if @crossid = !i ' Detrend using HP-filter ln_gdp_sa.hpf(lambda=1000) gdp_hp next
where I have a series named ln_gdp_sa for several countries. I attached my sample data only containing two countries.
Please let me know if there is any way to do HP-filtering for panel data using EViews.
Thank you very much for your help,
Futoshi
sampledata.wf1
(14.92 KiB) Downloaded 901 times
Postby EViews Gareth » Mon Feb 11, 2013 12:48 pm
You'll have to copy the series into a non-panel workfile.
fnarita
Postby fnarita » Mon Feb 11, 2013 1:11 pm
Hi Gareth,
Thank you so much for your very quick reply!
I'm trying to implement what you advised, but could you fix the following code?
The problem is I cannot copy back the HP filtered series to the paneled page, matching the crossid that is being worked on.
' Create a page to conduct HP-filtering pagecreate(page=nonpanel) q 1990q1 2012q2 pageselect Untitled1 ' Work on counry by country series temp = @crossid !ncross = @max(temp) delete temp for !i=1 to !ncross smpl if @crossid = !i ' Detrend using HP-filter copy(smpl="1990q1 2012q2") ln_gdp_sa nonpanel\ @src @date @dest @date pageselect nonpanel ln_gdp_sa.hpf(lambda=1000) gdp_hp ' Here is my problem copy(smpl="1990q1 2012q2") gdp_hp Untitled1\ @src @date @dest @crossid = !i @date pageselect Untitled1 next
fnarita
Postby fnarita » Mon Feb 11, 2013 3:21 pm
Hi all,
I figured it out by myself, but thank Gareth anyway for letting me know what I have to do.
I needed more lines and thoughts than I expected to fix my codes above, but anyway the following codes worked. Hope this would be a help to somebody else who wants to do panel HP-filtering using EViews.
' Open DATA workfile. open ./sampledata.wf1 smpl @all ' Create a page to conduct HP-filtering pagecreate(page=nonpanel) q 1990q1 2012q2 pageselect Untitled1 ' Work on counry by country series temp = @crossid !ncross = @max(temp) delete temp for !i=1 to !ncross ' Copy the series of interest to a page without a panel structure. %strsmpl ="1990q1 2012q2 if @crossid = !i" copy(smpl={%strsmpl}) ln_gdp_sa nonpanel\ @src @date @dest @date pageselect nonpanel ' Detrend using HP-filter. ln_gdp_sa.hpf(lambda=1000) gdp_hp_tmp ' Copy the results to the main page. copy gdp_hp_tmp Untitled1\ @src @date @dest @date pageselect Untitled1 smpl if @crossid = !i series gdp_hp = gdp_hp_tmp delete gdp_hp_tmp next smpl @all
Please let me know any easier ways and/or any mistakes. The sample data was attached again just for convenience.
Best Regards,
Futoshi
sampledata.wf1
(14.92 KiB) Downloaded 948 times
firoozehee
Postby firoozehee » Mon Sep 30, 2013 8:57 am
please help me :roll: :( . i have a panel data containing 14 countries for 25 years. i must specify oil shock in those countries. am i true or not? i have to estimate it one by one in all 14 countries? So how should I use them in panel data to estimate asymmetric effect of oil shock in GDP growth?
felix.casares
Postby felix.casares » Mon Aug 18, 2014 10:43 am
it doesn´t work to me :(
message error "copy(smpl={strsmpl}) ln_gdp_sa nonpanel\ @src @date @dest @date": strsmpl is not a valid string or scalar name
Please help, im build a panel data set and i want to do HP filter for each company
Hi all,
Best Regards,
Futoshi
Postby EViews Gareth » Mon Aug 18, 2014 11:20 am
Did you copy his line exactly?
felix.casares
Postby felix.casares » Mon Aug 18, 2014 11:50 am
yes i do, exactly
Postby EViews Gareth » Mon Aug 18, 2014 11:50 am
The error message would indicate you're missing a %
