Panel HP filtering
Panel HP filtering
I HP filtered a panel with 21 nations. Then I unstacked the panel, I took the raw variables and I HP filtered the series one by one (I mean country by country). Surprisingly the filtered output is not the same, why? any hints?
Thanks for helping me.
Re: Panel HP filtering
Hi.
I'm sure I understand what you mean by this question. HP filtering is not allowed on panel workfiles (EViews will produce an error message stating this if you try it).
How did you perform the HP filtering?
EViews 5
a) workfile with panel structure
b) open one series
c) Proc/HP Filter
d) you got the original series filtered
Thanks a lot for your prompt reply
b) open one series
c) Proc/HP Filter
What is the build date of your copy of EViews 5?
(You can check this by clicking on Help->About EViews).
"Standard Edition - Aug 20 2004 build"
You're very out-of-date. You should update your copy.
Hi all,
I would like to know any update available on this issue since EViews version 5.
I'm using EViews version 7.2, but having a trouble in HP-filtering using panel data.
My code is:
where I have a series named ln_gdp_sa for several countries. I attached my sample data only containing two countries.
Please let me know if there is any way to do HP-filtering for panel data using EViews.
Thank you very much for your help,
Futoshi
My code is:
' Work on counry by country
series temp = @crossid
!ncross = @max(temp)
delete temp
for !i=1 to !ncross
smpl if @crossid = !i
' Detrend using HP-filter
ln_gdp_sa.hpf(lambda=1000) gdp_hp
Futoshi
- sampledata.wf1
- (14.92 KiB) Downloaded 901 times
You'll have to copy the series into a non-panel workfile.
Hi Gareth,
Thank you so much for your very quick reply!
I'm trying to implement what you advised, but could you fix the following code?
The problem is I cannot copy back the HP filtered series to the paneled page, matching the crossid that is being worked on.
' Create a page to conduct HP-filtering
pagecreate(page=nonpanel) q 1990q1 2012q2
pageselect Untitled1
delete temp
for !i=1 to !ncross
copy(smpl="1990q1 2012q2") ln_gdp_sa nonpanel\ @src @date @dest @date
pageselect nonpanel
' Here is my problem
copy(smpl="1990q1 2012q2") gdp_hp Untitled1\ @src @date @dest @crossid = !i @date
Hi all,
I figured it out by myself, but thank Gareth anyway for letting me know what I have to do.
I needed more lines and thoughts than I expected to fix my codes above, but anyway the following codes worked. Hope this would be a help to somebody else who wants to do panel HP-filtering using EViews.
Please let me know any easier ways and/or any mistakes. The sample data was attached again just for convenience.
Best Regards,
Futoshi
' Open DATA workfile.
open ./sampledata.wf1
smpl @all
delete temp
for !i=1 to !ncross
' Copy the series of interest to a page without a panel structure.
%strsmpl ="1990q1 2012q2 if @crossid = !i"
copy(smpl={%strsmpl}) ln_gdp_sa nonpanel\ @src @date @dest @date
pageselect nonpanel
' Detrend using HP-filter.
ln_gdp_sa.hpf(lambda=1000) gdp_hp_tmp
' Copy the results to the main page.
copy gdp_hp_tmp Untitled1\ @src @date @dest @date
series gdp_hp = gdp_hp_tmp
delete gdp_hp_tmp
smpl @all
Best Regards,
Futoshi
- sampledata.wf1
- (14.92 KiB) Downloaded 948 times
firoozehee
please help me
:( . i have a panel data containing 14 countries for 25 years. i must specify oil shock in those countries. am i true or not? i have to estimate it one by one in all 14 countries? So how should I use them in panel data to estimate asymmetric effect of oil shock in GDP growth?
please help me
felix.casares
it doesn´t work to me :(
message error "copy(smpl={strsmpl}) ln_gdp_sa nonpanel\ @src @date @dest @date": strsmpl is not a valid string or scalar name
Please help, im build a panel data set and i want to do HP filter for each company
Hi all,
Please let me know any easier ways and/or any mistakes. The sample data was attached again just for convenience.Code: Select all
' Open DATA workfile. open ./sampledata.wf1 smpl @all ' Create a page to conduct HP-filtering pagecreate(page=nonpanel) q 1990q1 2012q2 pageselect Untitled1 ' Work on counry by country series temp = @crossid !ncross = @max(temp) delete temp for !i=1 to !ncross ' Copy the series of interest to a page without a panel structure. %strsmpl ="1990q1 2012q2 if @crossid = !i" copy(smpl={%strsmpl}) ln_gdp_sa nonpanel\ @src @date @dest @date pageselect nonpanel ' Detrend using HP-filter. ln_gdp_sa.hpf(lambda=1000) gdp_hp_tmp ' Copy the results to the main page. copy gdp_hp_tmp Untitled1\ @src @date @dest @date pageselect Untitled1 smpl if @crossid = !i series gdp_hp = gdp_hp_tmp delete gdp_hp_tmp next smpl @all
Best Regards,
Futoshi
Did you copy his line exactly?
felix.casares
yes i do, exactly
The error message would indicate you're missing a %
