correcting t stat in panel
hello!
i have a panel data analysis. least squares estimation, fixed effects.
so, i want to correct t statistics for heteroscedasticity, but i don't know how.
what do i have to do? do i go to panel options and change weights and/or coefficient covariance method?
Re: correcting t stat in panel
please help me if anyone knows :(
Econometrics_is_fun
Hello obicna(=ordinary)!please help me if anyone knows :(
First, in panel data sets you not only will have problems with heteroscedasticity but autocorrelation as well.
I would thus advise you to select White Cross section in coefficient covariance method menu.
hello. thank you!
so, by selecting white cross section i can eliminate both problems (autocorr and heteros.)?
so how do i correct autocorr?
Econometrics_is_fun
You correct for H and AC as I wrote earlier.so how do i correct autocorr?
With this method you can mitigate the problems facing you but not remove them. Autocorrelation in panel data is truly an enemy to us all. You can read more about this here http://forums.eviews.com/viewtopic.php?f=4&t=4448
many thanks!
The White cross section method corrects standard errors for heteroskedasticity. It does not correct for autocorrelation.
when you said no, i asked you how can i correct autocorr, i didn't ask you this (quoted).The White cross section method corrects standard errors for heteroskedasticity. It does not correct for autocorrelation.
I was responding to the post by Econometrics_is_fun.
I don't believe that EViews offers autocorrelation consistent standard errors in panels. You can, however, include an AR(1) term in the regression.
oh, i am sorry. i thought you were respondig to mine comments :)I was responding to the post by Econometrics_is_fun.
the problem is, when i use ar(1) , eviews says near singular matrix :?
That's puzzling.
