correcting t stat in panel
obicna89
Postby obicna89 » Fri Jul 01, 2011 7:13 am
hello!
i have a panel data analysis. least squares estimation, fixed effects.
so, i want to correct t statistics for heteroscedasticity, but i don't know how.
what do i have to do? do i go to panel options and change weights and/or coefficient covariance method?
obicna89
Re: correcting t stat in panel
Postby obicna89 » Sat Jul 02, 2011 4:07 am
please help me if anyone knows :(
Econometrics_is_fun
Postby Econometrics_is_fun » Sat Jul 02, 2011 6:41 am
Hello obicna(=ordinary)!
First, in panel data sets you not only will have problems with heteroscedasticity but autocorrelation as well.
I would thus advise you to select White Cross section in coefficient covariance method menu.
obicna89
Postby obicna89 » Sat Jul 02, 2011 6:44 am
hello. thank you!
so, by selecting white cross section i can eliminate both problems (autocorr and heteros.)?
Postby startz » Sat Jul 02, 2011 7:41 am
No.
obicna89
Postby obicna89 » Sat Jul 02, 2011 8:23 am
so how do i correct autocorr?
Econometrics_is_fun
Postby Econometrics_is_fun » Sat Jul 02, 2011 8:46 am
You correct for H and AC as I wrote earlier.
With this method you can mitigate the problems facing you but not remove them. Autocorrelation in panel data is truly an enemy to us all. You can read more about this here http://forums.eviews.com/viewtopic.php?f=4&t=4448
obicna89
Postby obicna89 » Sat Jul 02, 2011 8:50 am
many thanks!
Postby startz » Sat Jul 02, 2011 9:23 am
The White cross section method corrects standard errors for heteroskedasticity. It does not correct for autocorrelation.
obicna89
Postby obicna89 » Sat Jul 02, 2011 9:58 am
when you said no, i asked you how can i correct autocorr, i didn't ask you this (quoted).
Postby startz » Sat Jul 02, 2011 10:06 am
I was responding to the post by Econometrics_is_fun.
I don't believe that EViews offers autocorrelation consistent standard errors in panels. You can, however, include an AR(1) term in the regression.
obicna89
Postby obicna89 » Sat Jul 02, 2011 11:30 am
oh, i am sorry. i thought you were respondig to mine comments :)
the problem is, when i use ar(1) , eviews says near singular matrix :?
Postby startz » Sat Jul 02, 2011 12:35 pm
That's puzzling.
