If I CTRL C a figure from the result, Eviews puts up a dialog window on copy precision, which slows my work - as it constantly pops up when I CTRL C something. If I want to quickly CTRL C and CTRL V a few numbers from the Eviews results to MS Excel, this constantly bothering dialog box will prolong the operation at least 5 fold (from 2 seconds to 10 second). Can I somehow stop this dialog from appearing every time I want copy something?
I have a similar issue when I run the program, it constantly puts the dialog box on Programme name path etc. I update the program and run it and update and run it and update and run it… and this dialog-box constantly pops up. Can I get rid of it?
P.S. Imagine MS Excel/Word/Outlook would asked you each time you copy something you want it formatted or unformatted and you would lose 30 minutes of your life each day on this dialog box.
Eviews - Copy Precision Annoys
Re: Eviews - Copy Precision Annoys
I agree that the copy dialog is irritating when you're doing a lot of CTRL-C, CTRL-V work. It is something that we're going to spend some time seeing if we can come up with a solution to, although I'm not sure what it could be right now.
Just put an option into Options where I could define that every time I CTRL C something, it will be "formated", "unformated", or "Eviews will ask". Seems easy, isn't it?
How about the Dialog Box that pops up when I press "Run" in a program? It's called "Run Program" dialog box. It also annoyes when you update and run the program many times when writing it. Can I get red of it? I assume you get this dialog box a lot since you "program" daily.
The problem is that half of the time you want "formatted" and half of the time you don't. It isn't a personal preference type option, rather it is a "why are you coping" type option. When I'm copying an EViews regression into Word, I want the formatted version. When I'm copying a coefficient vector into Excel, I want the unformatted.
I don't actually program daily :D, and often programs require arguments, so that dialog is sort of essential. We can probably make it that the run short-cut key (either the existing one, or a new one) doesn't bring up the dialog though.
For me 2.836066 is fine. I do not need 2.836066169871948 even when copying it to MS Excel. I wonder what do you do with the 0.000000169871948 part? :D I am already imagining our Chief Economist comming to my office screaming that my US GDP Growth forcast was wrong by 0.000000169871948. :D
