Unstacking panel
naturama
Unstacking panel
Postby naturama » Thu Feb 19, 2009 3:46 am
I got a panel from an excel dataset.
First: the "cross id" in excel were "country names" (e.g. australia) but eviews took instead numbers (one for australia , 2 for the second nation and so on). Is there any any to get directly "country names"?
So, I used "valmap" to assign names to numbers.
Second: I am now interest in unstacking the panel but the "id" series with "valmap" is not accepted and I must use the one with numbers. Unfortunately this means that the new series have names like "gdp1","gdp2" and not "gdpaustralia" and so on and I have to rewrite the name of each variable by hand: is there a way to get directly "gdpaustralia"?
Thanks for helping me
Re: Unstacking panel
Postby EViews Gareth » Thu Feb 19, 2009 9:30 am
I can't think of any reason why EViews would read in a column of text in Excel containing country names, and convert that column into a series of numbers. Are you sure that is what happened?
naturama
Postby naturama » Fri Feb 27, 2009 2:45 am
Yes, I am quite sure.
I attach excel and work file.
Thank you
sent.WF1
(168.83 KiB) Downloaded 596 times
sent.XLS
(233 KiB) Downloaded 579 times
Postby EViews Gareth » Fri Feb 27, 2009 9:07 am
I have no idea what you did to get the data into EViews, but when I open that Excel file in EViews, the county variable comes in perfectly.
