I have 2 pages in a workfile. Each page is structured by a security identiifer and date. Page one is structrued by a daily date and security identifier (call it dailyPage). Page two is structured by a monthly date and security identifier (call it monthlyPage). I simply want to copy some pricing data (call it Price) from the dailyPage to the monthlyPage. Basically I want to only copy monthend pricing from the dailyPage to the monthlyPage. This is essentially a copy from High Frequency to Low Frequency. This is what I have tried :
1. pageselect MonthlyPage; copy(merge) DailyPage\Price Price @src securityID date @dest securityID date -> this works BUT its VERY slow
2. pageselect MonthlyPage; copy(merge,c=l) DailyPage\Price Price -> this works but it replaces a mismatch with the last nonmissing observations -> HOWEVER, what i want is to replace mismatches with merely NAs. How do i do that????
Copy Match Merge
Re: Copy Match Merge
Would it be possible to post (or email us support@eviews.com) the workfile? The first copy should not be slow.
The workfile is very big...around 500MBs...can this be posted???
No, that's a little large. However you might be able to save it with compression on (if it doesn't ask you when you save the file, click on Options->General Options->Data Storage), and then zip the workfile up in Windows. They can get a lot smaller.
I tried to upload the zipped workfile (~8MB) but I get this error...
The proxy could not connect to the given URL, this may be due to a problem with the destination webserver.
URL: http://forums.eviews.com/posting.php?mo ... f=3&t=4100
Filename:
Media Type (detected): application/x-empty
Media Type (from file name):
For assistance, please contact your system administrator.
generated 2011-04-20 23:32:48 by McAfee Web Gateway
Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729) DB Proxy Name: nj02ga03cmp01
Filename:
Try emailing it to support@eviews.com. Our email servers should accept an 8mb file.
With regards to your second line of code, rather than using "date" as the date ID, try using "@date" as the date ID.
marilyn099
Have you solved this problem? I guess buy cialis now I have something similar now.... :(
