Hi everyone,
I was trying to work with panel estimation. After estimation, I wanted to plot the dependent variable against a independent variable to get a parabola showing that the trend goes up for some time but decline overtime.
Another question is when i used the fixed effect option an error near singular matrix pops up. No prob with random effect. I have variable GDP and GDP square. When I drop GDP square no problem.
Can anyone tell me how to do it in eviews?
Plot
Re: Plot
Put the dependent and independent variables into a group, then select View->Graph->XY Line.
The singular matrix error is probably because you've got some sort of perfect collinearity between your regressors (including the fixed effects).
Envirogate
Re: Plot
Thanks for the quick response. But the suggested procedures will only help on the actual values of my variables. I wanted to plot the fitted or post estimation.
Re: Plot
Then use the forecast button to generate the fitted values.
