Multivariate Normality test: different results!
Sanke Charmer
Postby Sanke Charmer » Thu Nov 11, 2010 11:51 am
Hi!
I ran a VECM model in eviews 7.1 and when I test for multivariate normality the Ho cannot be rejected at conventional significance levels, BUT when I do the same tests (Cholesky, Doornik-Hansen and Urzua) in Eviews 6, the null was strongly rejected !!! :shock:
:?: Is there a problem in eviews 7.1 or eviews 6? Whats the source of the difference?
consumo_08112010.wf1
The VECM is in the object equation VEC01
(64.09 KiB) Downloaded 605 times
Re: Multivariate Normality test: different results!
Postby EViews Gareth » Thu Nov 11, 2010 12:23 pm
Your EViews 6 is probably out of date. When I run them in my version 6, they match those in version 7. There was a change made to the VAR normality tests in October 2008 to change the degree of freedom correction used.
