I ran a VECM model in eviews 7.1 and when I test for multivariate normality the Ho cannot be rejected at conventional significance levels, BUT when I do the same tests (Cholesky, Doornik-Hansen and Urzua) in Eviews 6, the null was strongly rejected !!!
Multivariate Normality test: different results!
Sanke Charmer
Hi!
Is there a problem in eviews 7.1 or eviews 6? Whats the source of the difference?
- consumo_08112010.wf1
- The VECM is in the object equation VEC01
- (64.09 KiB) Downloaded 585 times
Re: Multivariate Normality test: different results!
Your EViews 6 is probably out of date. When I run them in my version 6, they match those in version 7. There was a change made to the VAR normality tests in October 2008 to change the degree of freedom correction used.
