Variance Ratio Test
maryameco65
Variance Ratio Test
Postby maryameco65 » Tue Oct 19, 2010 9:46 pm
Hi Dear Eviews users,
I have a problem in eviews7 for variance ratio test. Because it always sends me this error: Illegal specification for the user-specified number of periods(must be a uniqe set of integer values greater than 1)
What should I do?
It would be grateful if you could help me.
Thanks in advance.
Re: Variance Ratio Test
Postby EViews Gareth » Tue Oct 19, 2010 9:57 pm
You should specify a unique set of integer values greater than 1 for the number of periods.
maryameco65
Postby maryameco65 » Wed Oct 20, 2010 1:04 am
such a great help.......!!!!!!
this error is also exist for runnig example files according eviews user guide!
if it is possible please help more
maryameco65
Postby maryameco65 » Wed Oct 20, 2010 1:11 am
my number of periods are for example 2 4 8 16 or 2 5 10 30
they are integer values greater than 1, but why eviews7 sends this error?
trubador
Did you use forum search?
Postby trubador » Wed Oct 20, 2010 1:53 am
Could you please post your workfile? Nothing seems wrong with the test and the example files...
maryameco65
Postby maryameco65 » Wed Oct 20, 2010 4:37 am
maybe the problem is for my eviews! not the tests and workfile
i used different eviews7, bur maybe they are not original
the RETURN is log dif of TEPIX
tepix.wf1
(19.2 KiB) Downloaded 282 times
trubador
Postby trubador » Wed Oct 20, 2010 4:56 am
As you see, everything works fine...
Variance Ratio Test Output for RETURN
maryameco65
Postby maryameco65 » Wed Oct 20, 2010 7:23 am
I appriciate your help and your answer
then the problem is for my eviews software, that does not work well!
what should I do? would it be possible to send me your eviews please?
maryam.eco65@yahoo.com
thanks too much
Postby EViews Gareth » Wed Oct 20, 2010 7:59 am
What is the build date on your copy (Help->About EViews)
maryameco65
Postby maryameco65 » Wed Oct 20, 2010 8:52 am
may 12 2010
Postby EViews Gareth » Wed Oct 20, 2010 9:00 am
You should update it to the latest version (Help->EViews Update)
maryameco65
Postby maryameco65 » Thu Oct 21, 2010 12:49 am
sorry, but after updating it needs registration ! and my Eviews does not open any more :(
I can not register
please help me
Postby EViews Gareth » Thu Oct 21, 2010 8:15 am
email support@eviews.com with your serial number and we'll handle the registration for you.
tiger_biskua
Postby tiger_biskua » Tue Dec 06, 2016 10:13 am
its also happend to me..can anyone help me
What should I do?
Thanks in advance.
Postby EViews Gareth » Tue Dec 06, 2016 10:31 am
Update your copy of EViews.
