Variance Ratio Test
maryameco65
Variance Ratio Test
Hi Dear Eviews users,
I have a problem in eviews7 for variance ratio test. Because it always sends me this error: Illegal specification for the user-specified number of periods(must be a uniqe set of integer values greater than 1)
What should I do?
It would be grateful if you could help me.
Thanks in advance.
What should I do?
Thanks in advance.
Re: Variance Ratio Test
You should specify a unique set of integer values greater than 1 for the number of periods.
maryameco65
such a great help.......!!!!!!
this error is also exist for runnig example files according eviews user guide!
if it is possible please help more
maryameco65
my number of periods are for example 2 4 8 16 or 2 5 10 30
they are integer values greater than 1, but why eviews7 sends this error?
Could you please post your workfile? Nothing seems wrong with the test and the example files...
maryameco65
maybe the problem is for my eviews! not the tests and workfile
i used different eviews7, bur maybe they are not original
the RETURN is log dif of TEPIX
- tepix.wf1
- (19.2 KiB) Downloaded 283 times
As you see, everything works fine...
maryameco65
I appriciate your help and your answer
then the problem is for my eviews software, that does not work well!
what should I do? would it be possible to send me your eviews please?
maryam.eco65@yahoo.com
thanks too much
thanks too much
What is the build date on your copy (Help->About EViews)
You should update it to the latest version (Help->EViews Update)
maryameco65
sorry, but after updating it needs registration ! and my Eviews does not open any more :(
I can not register
please help me
I can not register
please help me
email support@eviews.com with your serial number and we'll handle the registration for you.
tiger_biskua
its also happend to me..can anyone help me
What should I do?
Thanks in advance.
What should I do?
Thanks in advance.
Update your copy of EViews.
