Dear there
Recently I am trying to programming a Kalman filter in Eviews 6.0. In this programming, I use matrix and vector operation in logl for likelihood function. However, when I am running it, it always report some errors regarding the matrix and vector as in the following picture. I am wondering if anyone could tell if matrix or vector actually can be used in logl or not. Sometimes I think we only could use series in logl, right??? If this is true, that's really inconvenience. I really appreciate anyone help.
The following is my Eviews code
' Improving out-of-sample equity premium prediction: the role of learning
'David E. Rapach, Tao Zha, and Guofu Zhou
'open oos.wf1 workfile which includes the data imported already
wfopen "C:\Users\MM\Desktop\OOS-Learning materials\oos"
delete s0
delete s1
sample s0 1926m12 2008m12
sample s1 1927m02 2008m12
smpl s0
series y=eret
series x1=dy
series x2=de
'get starting values from ols
equation eq1.ls eret c bm de
'Initialization of parameters and starting values
coef(4) mu
mu(1)= eq1.c(1)
mu(2)=eq1.c(2)
mu(3)=eq1.@se^2
mu(4)=0.1
vector(@rows(y)) alpha
alpha(1)=eq1.c(3)
alpha(2)=0.2
vector(@rows(y)) H
H(1)=0.02
vector(@rows(y)) yy
yy(2)=alpha(2)*x2(1)
vector x22=x2
vector x11=x1
!mlog2pi = 2*log(2*@acos(-1))
'LOG LIKELIHOOD
'set up the likelihood
' 1) open a new blank likelihood object name oos
' 2) specify the log likelihood model by append
logl ll1
ll1.append @logl logl1
for !i=3 to @rows(y)
ll1.append H(!i-1)= 1/( 1/H(!i-2) + mu(4)*( x22(!i-2)*x22(!i-2)-1/H(!i-2) ) )
ll1.append alpha(!i)= alpha(!i-1) + mu(4)*H(!i-1)*x22(!i-2)*( x11(!i-1)-x22(!i-2)*alpha(!i-1) )
ll1.append yy(!i)=alpha(!i)*x22(!i-1)
ll1.append res1 = y-mu(1)-mu(2)*x1(-1)-yy(-1)
ll1.append logl1 =-0.5*!mlog2pi -0.5*log(mu(3))-0.5*(res1^2/mu(3))
smpl s1
ll1.ml(showopts, m=100, c=1e-5)
'change below to display different output
show ll1.output
a programming error for matrix in logl
Matrix objects cannot be used inside a LogL.
Re: a programming error for matrix in logl
Is there any way to work out this matrix loop? something like writing a function or subroutine, then call the subroutine from logl.............
LogL objects exist outside of the programming language, so you can not use any programming language constructs (loops, subroutines etc...) inside them.
Is there a way to not use matrix in my code for logl? I cannot figure out how to do my code if I do not use loops or matrix? Thanks
