Question regarding first differences
Christian_87
Postby Christian_87 » Mon Mar 24, 2014 5:23 am
Hello
At the moment I am building an AR(2) modell (times series) were I have a produced a forecast. To achive stationarity I had to take the log first differences of my variables before making the forecast. The forecast has given me forecasted first differences values. My question is how do I recalculate the forecasted values back to its "original values"? I have tried a thing like x1+x1(+1) ( the opposite of first differnces, but it doesent work.)
Thanks in advance!
Re: Question regarding first differences
Postby startz » Mon Mar 24, 2014 6:35 am
If you make your forecast variable d(x), instead of defining a new variable equal to d(x), EViews will forecast x for you.
Christian_87
Postby Christian_87 » Tue Mar 25, 2014 1:28 am
Thanks for the quick answer!
Iam not shore of what you are meaning exactly. So if I get a forecasted variable that is log diff, should i transform the forecasted variable log diff to its original value? Or is their some kind of function in Eviews that i should use?
Postby startz » Tue Mar 25, 2014 6:27 am
Try the following regressions and then forecasting from each to see what variables are created by the forecast.
ls d(x) c z ls dlog(x) c z
Christian_87
Postby Christian_87 » Wed Mar 26, 2014 2:33 am
Thanks!
It works now!
