I am completely new to eViews and I wanted to ask how exactly should I write the equation (see attachment) into eViews?
How would I input this equation into eViews?
LeonWalras
Hello everyone,
- Equation.JPG (11.72 KiB) Viewed 5426 times
Re: How would I input this equation into eViews?
You should estimate it with NLS like this:
ls y=c(1)*k^c(2)*l^c(3)*e^c(4)*m^c(5)
By default EViews put the error term. Be careful with the starting values of the parameters, you could introduce them in the c vector-coeficcient.
You're probably better off taking logs.
Gareth is correct since you probably want an additive error.
LeonWalras
I agree, as I want to do a least squares estimate on it. But how would I type this into eViews?You're probably better off taking logs.
