Control the number of decimals
Posted: Sat Mar 08, 2014 1:12 pm
by Pantera
Hi all,
I have a made a plot showing the relation between x (horizontal axis) and y (vertical axis). Problem: the x-axis shows the decimals which is not that nice. Question: How can I get rid of the decimals on the x-axis?
Regards,
Sent from my SM-N9005 using Tapatalk
Re: Control the number of decimals
Posted: Sat Mar 08, 2014 2:46 pm
What would you like to show instead?
Posted: Sat Mar 08, 2014 2:48 pm
by Pantera
Hi - just the numbers without any decimals.
Posted: Sat Mar 08, 2014 2:52 pm
by Pantera
I have made the figure, but did not succeed in editing the numbers on the x-axis.
Posted: Sat Mar 08, 2014 3:07 pm
You mean you want to round the displayed numbers?
Posted: Sat Mar 08, 2014 3:24 pm
by Pantera
Yes, that's correct.
Posted: Sat Mar 08, 2014 4:32 pm
Open the graph dialog, click on Axes & Scaling -> Data axis labels, then change the Decimals Places combo to "0".
Posted: Sun Mar 09, 2014 3:56 am
by Pantera
Unfortunately the option does not work. The series I'm analyzing is "Undated with ID series" and the "Identifier series" I have selected (and which is the x-axis) is a series with decimals. Anyway, I also expected that the option you recommend should work when editing the plot - but it did not.
Posted: Sun Mar 09, 2014 9:06 am
Post the workfike
Posted: Sun Mar 09, 2014 9:17 am
by Pantera
Hi - See attached workfile. The "adtime" is the x-axis. Try for example to plot the variable "nps".
Posted: Sun Mar 09, 2014 11:01 am
You don't have any decimals in adtime. When I graph it, it doesn't show decimals.
Posted: Sun Mar 09, 2014 12:42 pm
by Pantera
Mysterious --- I have attached a print-screen so you can see what I see. (I selected and opened the variabel PNS, then selected Graph)
Posted: Sun Mar 09, 2014 3:11 pm
Ah, I had assumed you were doing a scatter graph.
Open up the Adtime series, hit Properties, then change the display format. Then recreate your graph.
Posted: Sun Mar 09, 2014 3:22 pm
by Pantera
Thank Gareth - you solve the problem!
