Reading txt-file, special case
johansamuelsson
Contact:
Postby johansamuelsson » Tue Mar 04, 2014 3:27 am
I'm making a API-call via a VBA-script in order to get some data. The VBA-script creates a txt-file (see attached file).
I'm using
wfopen "G:\Pro\Led\ProcessMetod\Api\Data\Data.Txt" skip=1 colhead=1 delim="," byrow pagestruct(freq=q, start=1993)
I have problem to tranforme the data from alphaseries to timeseries. I've tried using
types = "f"
but Eviews transform wrong because I have space delimiter characters in the numbers?
How to do?
Regards Johan
Data.txt
(16.31 KiB) Downloaded 443 times
Re: Reading txt-file, special case
Postby EViews Gareth » Tue Mar 04, 2014 9:03 am
Just so I understand correctly, the number:
is actually one number (385179)?
johansamuelsson
Contact:
Postby johansamuelsson » Tue Mar 04, 2014 11:31 am
Yes
EViews Chris
Postby EViews Chris » Tue Mar 04, 2014 12:16 pm
I'm afraid you'll have to get rid of those spaces inside the numbers somehow. I don't remember anyone asking us to read in a numeric field formatted like that before and there's currently no built in support for it.
Actually, it turns out they're not ordinary spaces (character code 32) but non-breaking spaces (character code 160) inside your fields which makes it even less likely that we'll handle this automatically.
I think your only option within EViews is to translate the series yourself after loading them in, something like this
series import_av_varor_ = @val(@replace(import_av_varor, @chr(160), ""))
You could loop over all the series in a program by putting the series in a group and translating them within a loop.
johansamuelsson
Contact:
Postby johansamuelsson » Tue Mar 04, 2014 12:46 pm
Ok, thanks
