i need to read data from .xlsx file, i already search on the forum and some suggest to use the wfopen command but it is used to read data when we already an opened workfile so what i have to do to make that command work like this one (this command work on xls):
Read(S=TCE,T,c3) "E:\DMHOCP1981200.xls" 5
Thanks in advance.
Get data from .xlsx file
Re: Get data from .xlsx file
Use the Import command.
Can i get the right syntax using import command to replace the one above please.Use the Import command.
any help please how to use the import command to open xlsx file, i already use a script that use the read command :
how to convert the syntax above using the import command.
Thanks in advance for your help
Read(S=TCE,T,c3) "E:\DMHOCP1981200.xls" 5Thanks in advance for your help
