Hi, I am a novice in eviews and still learning (hard :) actually. I recently stumbled on the way to do the same thing using command.
I did panel estimation and I can view the result of fix / Random effects through interactive window by doing:
View - Fixed/Random Effects - Cross-section effects OR Period effects.
But I cannot view that using command programming. Is there anyone know how to do it?
Second question: How to put residcor result method to matrix? I can only freeze them into a table but cannot put them into a matrix by doing:
matrix mat = eqsur.residcor
Eviews will issue Syntax error
Gimel
Asking command to view result of panel
Re: Asking command to view result of panel
1) eqname.effects (if you actually have a panel equation. For a pool object, I'm not sure you can).
2) I think you'll have to calculate the correlation matrix yourself from the residuals of the pool object.
For part 2):
where p is the name of your pool object.
p.makeresids pr?
group g pr?
g.cor(ucor,out=mat)
The result will be in matcorr.
Note that pools display the effects in the main estimation output window.
