HELP! Time series data,unit roo, log, Johansen, Var or VECM
Divisible
Postby Divisible » Sun Feb 23, 2014 4:37 pm
Hello guys,
I am dealing with 10 years time series monthly data.
To run my regression, all variables have to be converted into log's. What I dont understand is, when i do unit root test, Johansen test and var, do i need to use variables that are converted to log's or no? Or just use all normal variables, and after doing the tests, convert everything to log's and run the regression.
Thank you
Re: HELP! Time series data,unit roo, log, Johansen, Var or V
Postby startz » Sun Feb 23, 2014 5:16 pm
If your analysis is going to be in logs, then convert everything to logs first.
