Error in estimating an Exponential Trend
vksf
Postby vksf » Fri Feb 21, 2014 6:10 pm
I am using Eviews 8 and I am getting an overflow/error message when I am estimating an exponential trend. I have typed the following equation under the quick tab using LS. (r is the independent variable and t=1,2,... is the time trend) Please find my workfile attached.
r c(1)*exp(c(2)*t)
It would be great if someone could help with this problem
Hazel.WF1
(20.5 KiB) Downloaded 196 times
Re: Error in estimating an Exponential Trend
Postby EViews Gareth » Fri Feb 21, 2014 6:22 pm
You're missing an equals sign
vksf
Postby vksf » Fri Feb 21, 2014 6:34 pm
Thanks Gareth. Even with the = it does not work.
I've even tried typing ls r = c(1)*exp(c(2)*t) in the command window
vksf
Postby vksf » Fri Feb 21, 2014 6:54 pm
I redid the exercise and it says "Near Singular Matrix Error. Regressors may be perfectly collinear"
Postby startz » Fri Feb 21, 2014 9:46 pm
Try typing
c=0.5
before you do the estimate
vksf
Postby vksf » Tue Feb 25, 2014 4:45 pm
Thanks but does this solve the singularity issue? What is the basis for selecting c?
Postby EViews Gareth » Tue Feb 25, 2014 4:47 pm
Just choose something other than zero. It should remove the singularity error.
