AUTOCORRELATION CANNOT BE REMOVED
sirooskhadem
Postby sirooskhadem » Thu Feb 13, 2014 9:35 pm
I have been trying to remove the Autocorrelation from my model but it seems impossible. The best results come from an ARMA-EGARCH model with Student’s t error distribution. I have also tried with no pre-sampling but still nothing. The data is 15-MINUTES Australian Dollar exchange rate returns against USD with 5 working days dummy variables. When I check the correlogram standardized of residuals, AC and PAC are very close to zero but highly significant. There is also a note there saying;”*Probabilities may not be valid for this equation specification.” Which I don’t know what does it mean.
Any suggestion?
Siroos
aud.rar
I HAD TO ZIP THE THE FILE SINCE IT IS MORE THAN 2MB
(1.72 MiB) Downloaded 594 times
eobumneke
Re: AUTOCORRELATION CANNOT BE REMOVED
Postby eobumneke » Mon Feb 24, 2014 6:59 am
Hello, if you want to remove autocorrelation in a model, there are one out of the 3 basic things you could do: Run a general-to-specific model, or change the dynamic specification of the model or add sufficient lags to both the dependent and independent variables. Moreso, bear in mind that Durbin watson test for autocorrelation is used ONLY for first order autocorrelation! once any of such correction methods i earlier stated are utilized, you have to use LM test for autocorrelation. Regards.
sirooskhadem
Postby sirooskhadem » Thu Mar 13, 2014 10:07 pm
Thank you very much for your reply.
