setformat for negative values
Katjes
Postby Katjes » Tue Jun 09, 2009 3:42 pm
I saved a correlation matrix for group grp in a table corr_grp
freeze(corr_grp) grp.cor
Now I want to optimise by reducing the decimals of 2. Everthing is fine if the correlation is positive, but for negative values the correlation is put in brackets.
corr_grp.setformat( @all) f(.2)
How can I change this, so that a (0.34) is shown as -0.34.
Re: setformat for negative values
Postby EViews Gareth » Tue Jun 09, 2009 3:50 pm
If you don't want the negatives in parenthesis, why did you use them in the format choice?
Surely you just want
corr_grp.setformat(@all) f.2
Katjes
Postby Katjes » Wed Jun 10, 2009 5:48 am
Ok, thanks, but if the numbers are only positive, then I got no brackets using my command above, hence I thought that I used the right command.
But I will skip the brackets! Thanks again!
