I am using this command:
for !n = 1 to 15
series ra{!n}=100*rs{!n}*nyf{!n}/p{!n}
It keeps giving me "Syntax Error". Any ideas what I can do?
Thanks,
Syntax Error
Re: Syntax Error
There's nothing wrong with that code. I can run it without any errors.
Re: Syntax Error
Thank you for the reply. Unfortunately, I still receive Syntax Error when I write it into the command window. Are there any pre-steps I should have taken? I assumed that "!n" represents my variables which I have 15 of.
Re: Syntax Error
Write it into a program rather than into the command window, and then run the program.Thank you for the reply. Unfortunately, I still receive Syntax Error when I write it into the command window. Are there any pre-steps I should have taken? I assumed that "!n" represents my variables which I have 15 of.
Re: Syntax Error
that was the issue! Thank you so much...
