Macro stops after import
viktorz
Postby viktorz » Tue Feb 04, 2014 4:47 am
Hi, I am using the com add-in to run some seasonal adjusting from Excel through Eviews. I am using following VBA code:
Sub SeaAdj() Dim mgr As New EViews.Manager Dim App As EViews.Application Dim sheet_update As Worksheet Dim asheet As Worksheet Set asheet = ActiveSheet Set App = mgr.GetApplication(ExistingOrNew) Dim datum As String datum = InputBox("Fill the data of the last known figure in Eviews format (e. g. 1998q1).", "Date") lspath = "Z:" App.Run "cd " & lspath App.Run "wfopen qpm_sk" App.Run "import(resize) Z:\922\923new\VYSTUPY\Slovakia\quarterly\Model\history_sk.xls range='Data'" App.Run "smpl 1998q1 " & datum App.Run "run seasonal_adjustment" ......
After the code performs the import line the macro stops withou a notice. Originally I had a program with import lines which called, but that ended in the same way.
Thanks for help.
Re: Macro stops after import
Postby EViews Gareth » Tue Feb 04, 2014 8:51 am
Are you sure it ends on the import command?
