Engle-Granger cointegration test
hsmellin
Postby hsmellin » Fri Jan 31, 2014 8:05 am
I am wondering if this is valid:
1. Take the residuals from an OLS regression and make a series, say resid01
2. Then inputting the code:
"coint(method = eg, trend =0) resid01"
I have been told i can do this with the PO test and wondered if the same held for this method of test.
Thanks,
M
Re: Engle-Granger cointegration test
Postby EViews Glenn » Fri Jan 31, 2014 8:12 am
You can do a unit root test on RESID01, but the critical values will be wrong. The best thing to do is to create a group with the series of interest, and then do the Engle-Granger or Phillips-Ouliaris test directly.
hsmellin
Postby hsmellin » Fri Jan 31, 2014 8:19 am
Thanks Glenn.
