Programming for dummies
eviewsuser77
Postby eviewsuser77 » Thu Jan 30, 2014 1:44 pm
Could you please help me: I need to estimate some equation for a set of individuals, so I am working on a program that would do so for all of them at once. Is it possible to do the following: for all the individuals I have a dummy variable, could I make EViews look at the values of the dummy and for all the cases when the dummy is equal to 1...:
1)... limit the sample for estimation to that observation (where the dummy=1) +/- some number of days?
2)... also assign values of 1 to some set of days around it (+/- a fixed number)?
I would be very grateful for your help and especially for some suggested code.
Thanks!
Re: Programming for dummies
Postby EViews Gareth » Thu Jan 30, 2014 1:50 pm
smpl if dummy=1 or dummy(-1)=1 or dummy(1)=1 equation eq1.ls...
eviewsuser77
Postby eviewsuser77 » Thu Jan 30, 2014 2:23 pm
Thanks for your message. I would really appreciate it if you could clarify a bit - could you please consider the 2 points I mentioned separately and suggest some solution?
Thanks!
Postby EViews Gareth » Thu Jan 30, 2014 2:28 pm
1)
2)
smpl if dummy=1 or dummy(-1)=1 or dummy(1)=1 series dum2 = 1
