I'm EViews 8 user. I've got this code which computes correlation table of five variables:
group gr1 var1 var2 var3 var4 var5
gr1.cor corr prob
freeze(corr_tab) gr1.cor corr prob
Is there a way to combine line 2 and 3 together without using command "freeze"? The thing is if you use "freeze" at the beginning of a line, it is sometimes difficult to understand what this line is doing, especially if you're not familiar with programming. So, I was thinking about a set of commands that would first create an empty table called "corr_tab" and then update the table to make it a correlation matrix. In summary, I think my question is about how to refer to existing tables.
Any suggestions welcome.
Best,
Pawel
Correlation table - save results
Re: Correlation table - save results
I'm not sure what you're asking. However, I'll point out that line 2 is completely unnecessary.
thanks for your reply. I do indeed realize that the second line is unnecessary. The reason why I do it is to show the students that I first create a table and then freeze it. If I put freeze at the beginning of the line, they may get a bit confused, especially if they have no experience with programming at all.
Another way of doing it would be to create an empty table first called corr_tab and then to update it by assigning a correlation matrix to it. I do it for graph. E.g.
graph price_dist price ' creates object of type graph called price_dist
price_dist.distplot hist theory(dist=normal) ' updates the graph price_dist to show a histogram and fitted normal density function
Is there a similar set of commands for tables?
Best,
Pawel
Best,
Pawel
Thanks for your reply.
