In a series or group, if I want to omit a outlier or a specific observation of the series, what should I write in the command line?
Please kindly advise. Thank you.
Omit a Outlier
Re: Omit a Outlier
use the smpl commandHi
smpl @allCode: Select all
smpl 1 9 11 100-
Leslie Hsu
Re: Omit a Outlier
Thank you, startz~
If there are several thousands of obs. in the series and roughly 10-30 outliers distribute everywhere, is there any method to omit these outliers. Otherwise, is it possible to delete these outlier? For example, we may write "if smpl=10 then delet" in SAS. Thank you.
Re: Omit a Outlier
Look up smpl if, as inThank you, startz~
smpl if some-logical-conditionWho is online
