"t stats not defined" error in rolling regression
jm13
Postby jm13 » Sun Nov 24, 2013 12:51 am
I'm trying to run a rolling regression and I am stopped from running it when this error message appears: "TSTATS not defined". How do I define the tstats so that I can run the rolling regression. My code is as follows:
workfile thesisA4
!window = 1000
!step = 1
!length = @obsrange
system sys09
sys09.append rstr=c(1)
sys09.append ngnr=c(2)
!nrolls = @round((!length- !window)/!step)
matrix(9, !nrolls) coefmat
matrix(9, !nrolls) tstats
!j=0
for !i = 1 to !length- !window+1- !step step !step
!j=!j+1
smpl @first+!i-1 @first+!i+!window-2
sys09.arch(b,h) @diagbekk c(fullrank) arch(1) garch(1)
colplace(coefmat, sys09.@coefs, !j)
colplace(tstats, sys09.@tstats, !j)
show coefmat
show tstats
I am using Eviews Student Version 6. I also looked at previous posts and did a search on the forum but could not find anything on t stats that was relevant. How can I alter the code so that this error will go away? Please help.
JM13
Re: "t stats not defined" error in rolling regression
Postby EViews Gareth » Sun Nov 24, 2013 5:18 pm
You appear to have written an EViews program. Given that the student version of EViews doesn't support programming, that's probably what is going wrong.
jm13
Postby jm13 » Mon Nov 25, 2013 1:06 am
Thanks for your answer and I will try it on a normal EViews. But I remember I once got it to work on the Student Version. Do you have any suggestions? Does the code seem OK anyway?
JM13
Postby EViews Gareth » Mon Nov 25, 2013 5:13 am
Yes
