"overflow of analytical derivatives" error
Posted: Fri Nov 22, 2013 5:30 am
by purdued
Hi all,
I'm currently trying to estimate an non-linear STR with the following:
smpl @all
series dr_uk = r_uk - r_uk(-1)
series ldr_uk = dr_uk(-1)
series t = @trend + 1
coef(1) gamma
coef(1) lambda
coef(7) beta
coef(7) theta
LS R_UK = (1 - 1/(1 + @exp(-gamma(1)*(t - lambda(1)))))*(BETA(1) + BETA(2)*R_UK(-1) + BETA(3)*LDR_UK + BETA(4)*PI_GUK + BETA(5)*Y_GUK + BETA(6)*PI_UK + BETA(7)*CLI_UK) + (1/(1 + @exp(-gamma(1)*(t - lambda(1)))))*(THETA(1) + THETA(2)*R_UK(-1) + THETA(3)*LDR_UK + THETA(4)*PI_GUK + THETA(5)*Y_GUK + THETA(6)*PI_UK + THETA(7)*CLI_UK)
I get an error saying "overflow of analytical derivatives" although I get estimates for my coefficients. What I don't get is a equation object.
Anyone knows what's happening here?
I'm new to eviews so I'm hoping its something stupid.
Dave
Re: "overflow of analytical derivatives" error
Posted: Fri Nov 22, 2013 2:54 pm
by EViews Glenn
Can you post your workfile?
Posted: Tue Nov 26, 2013 9:19 am
by purdued
Hi Glenn,
Here's the workfile, sorry for the delay.
I have a feeling all this is due to the spec of the pc I'm working on.
str_data.WF1
(123.58 KiB) Downloaded 784 times
Posted: Thu Nov 28, 2013 1:54 am
by trubador
Try assigning initial values to coefficients other than zero:
coef(1) gamma = .1 coef(1) lambda = .1 coef(7) beta = .1 coef(7) theta = .1
Posted: Fri Nov 29, 2013 10:41 am
by purdued
Thanks Trubador.
Changing initial values helps alright. the model is very sensitive to what you set them to though.
I can set the initial values to non-zero numbers and have gotten equation objects while other non-zero numbers will result in the error will pop up.
Is it possible a figure is tending to zero or infinity in the iterative process and that cuts it off (i'm not sure - just throwing ideas out there).
Dave
Posted: Mon Jul 07, 2014 4:34 am
by dsokhi
I am getting the same "overflow in analytical derivatives" error as soon as I add a dummy variable. Number of observations is greater than the number of variables on RHS. Also I tried to set the initial values of coefficients in 'c' to non-zero numbers (1 and -1).
Could you please let me know the reason why I get this error and how can I overcome it?
Thanks.
Note: Sorry I can't post the eviews file due to confidentiality of data!
Posted: Tue Jul 08, 2014 8:16 am
by EViews Glenn
Can you look at the Derivatives display to see the analytic derivatives? You can try to evaluate these expressions one by one to see which one is giving you problems.
