"overflow of analytical derivatives" error
purdued
Postby purdued » Fri Nov 22, 2013 5:30 am
Hi all,
I'm currently trying to estimate an non-linear STR with the following:
smpl @all
series dr_uk = r_uk - r_uk(-1)
series ldr_uk = dr_uk(-1)
series t = @trend + 1
coef(1) gamma
coef(1) lambda
coef(7) beta
coef(7) theta
LS R_UK = (1 - 1/(1 + @exp(-gamma(1)*(t - lambda(1)))))*(BETA(1) + BETA(2)*R_UK(-1) + BETA(3)*LDR_UK + BETA(4)*PI_GUK + BETA(5)*Y_GUK + BETA(6)*PI_UK + BETA(7)*CLI_UK) + (1/(1 + @exp(-gamma(1)*(t - lambda(1)))))*(THETA(1) + THETA(2)*R_UK(-1) + THETA(3)*LDR_UK + THETA(4)*PI_GUK + THETA(5)*Y_GUK + THETA(6)*PI_UK + THETA(7)*CLI_UK)
I get an error saying "overflow of analytical derivatives" although I get estimates for my coefficients. What I don't get is a equation object.
Anyone knows what's happening here?
I'm new to eviews so I'm hoping its something stupid.
Dave
Re: "overflow of analytical derivatives" error
Postby EViews Glenn » Fri Nov 22, 2013 2:54 pm
Can you post your workfile?
purdued
Postby purdued » Tue Nov 26, 2013 9:19 am
Hi Glenn,
Here's the workfile, sorry for the delay.
I have a feeling all this is due to the spec of the pc I'm working on.
str_data.WF1
(123.58 KiB) Downloaded 766 times
trubador
Did you use forum search?
Postby trubador » Thu Nov 28, 2013 1:54 am
Try assigning initial values to coefficients other than zero:
coef(1) gamma = .1 coef(1) lambda = .1 coef(7) beta = .1 coef(7) theta = .1
purdued
Postby purdued » Fri Nov 29, 2013 10:41 am
Thanks Trubador.
Changing initial values helps alright. the model is very sensitive to what you set them to though.
I can set the initial values to non-zero numbers and have gotten equation objects while other non-zero numbers will result in the error will pop up.
Is it possible a figure is tending to zero or infinity in the iterative process and that cuts it off (i'm not sure - just throwing ideas out there).
Dave
dsokhi
Postby dsokhi » Mon Jul 07, 2014 4:34 am
I am getting the same "overflow in analytical derivatives" error as soon as I add a dummy variable. Number of observations is greater than the number of variables on RHS. Also I tried to set the initial values of coefficients in 'c' to non-zero numbers (1 and -1).
Could you please let me know the reason why I get this error and how can I overcome it?
Thanks.
Note: Sorry I can't post the eviews file due to confidentiality of data!
Postby EViews Glenn » Tue Jul 08, 2014 8:16 am
Can you look at the Derivatives display to see the analytic derivatives? You can try to evaluate these expressions one by one to see which one is giving you problems.
