Label Graph Axis
rmoralesaramburu
Label Graph Axis
I need to label the bottom axis of my graph with dates. The dates I want are on an excel file, and are on a row and several columns. How can I program eviews to import does dates and label it on the bottom axis of my graph.
thanks!!
thanks!!
Re: Label Graph Axis
What is the graph of? How was it created?
Is there any special reason that the workfile containing the graph doesn't already have dates?
rmoralesaramburu
the graph is a line graph of a series
The workfile contains series, doesn't contain dates. I am importing data from excel with wfopen function
and the thing is that my series are in columns, column A is series1, column B is series2, .... and so on. but my dates are on a row, so Column A will have a date columnA on row1, column B a date con column B row1, and so on..
graph ois.line xseriesCode: Select all
wfopen(page=ois) "H:\10. Varios\Rodrigo Morales\Analisis\Program Inputs\FI\OIS_US.xlsx" range=sheet1!b8-
Could you provide the Excel file?
rmoralesaramburu
Here it is, in row 2 are the dates I need to use.
- OIS_US.xlsx
- so in row 2 I have the dates I will like
- (102.47 KiB) Downloaded 580 times
Problem is that you only have 47 dates (B2:AV2), yet you have 50 observations in the workfile (and thus, I presume, the graph). Where are the missing 3 dates?
rmoralesaramburu
The thing is I created a new series with 47 observation on Eviews (I extract an observation per column), and I would like to graph them, with the dates on row 2, so I have 47 dates, and 47 observations.
ok, could you provide the workfile with the graph (or the program that makes the graph)?
rmoralesaramburu
rmoralesaramburu
I'd do something like this:
wfopen(page=ois) "OIS_US.xlsx" range=sheet1!b8
matrix(47,1) months_to_hike
for !i = 1 to 47
smpl if fwd2013_!i<=0.5
matrix months_to_hike(!i,1)=@obs( fwd2013_!i)
pageload(page=dates) "ois_us.xlsx" byrow range=sheet1!b2:av2
alpha dates = @datestr(@date, "DD-MM-YY")
copy ois\months_to_hike dates\
mtos(months_to_hike)
rename ser01 monthshike
graph months.line monthshike
months.addtext(t,font("arial",12,b)) "Months to FED Hike"
save "H:\10. Varios\Rodrigo Morales\Analisis\EVIEWS\OIS_MonthHike.wf1"
rmoralesaramburu
thanks! just a question, what are you telling the program to do with
alpha dates = @datestr(@date, "DD-MM-YY")-
Oh, that line is not needed, I forgot to remove it.
rmoralesaramburu
Do you know how to label the last observation in a line graph? I would like to label just the LAST observation.
Thanks!
Thanks!
for !i = 1 to 47
smpl @last @last
smpl @all
months.setobslabel(series) dates
