Gregory-Hansen cointegration test
Posted: Sun May 31, 2009 5:07 pm
Dear trubador and others Eviews programming expert,
With the help from Trubador, I have written the following sets of codes for Gregory and Hansen (1996) cointegration test. Unfortunately, both codes seem to be correct but I am not sure why the results is vary between the programme used. In term of result, I think the second set of code should be correct, while the first set of code will produce more easy and presentable result. Therefore, I attempt to request the Eviews programming expert to improve the first codes. Of course, I would also appreciate that if the Eviews programming expert willing to write a more shorter and presentable code for the Gregory-Hansen test.
The Gregory-Hansen programming code were reported as below:
First set of GH code:
Second set of code:
Thank you in advance,
Warmest regards,
tcfoon
!trim = 0.15 'Trimming parameter
!t_min = 1000
!min_aic = 1000
vector(1) breaks
for !i = @round(@obs(sy)*!trim) to @round(@obs(sy)*(1-!trim))
smpl @all
equation temp.ls SY c IY (@trend>!i)
temp.makeresid EEC
genr ZZ = EEC
genr DZZ = D(EEC)
for !lag = 0 to 4
if !lag = 0 then
equation temp.ls DZZ ZZ(-1)
else
equation temp.ls DZZ ZZ(-1) DZZ(-1 TO -!lag)
endif
if temp.@aic < !min_aic then
!best_lag = !lag
!min_aic = temp.@aic
if temp.@tstats(1) < !t_min then
!t_min = temp.@tstats(1)
breaks(1) = !i+2 'Identified first break point.
series DU1 = @trend> !i
series DT1 = DU1*(@trend-!i)
if !best_lag = 0 then
equation GH.ls DZZ ZZ(-1)
else
equation GH.ls DZZ ZZ(-1) DZZ(-1 TO -!best_lag) 'Selected equation
endif
endif
endif
delete tempCode: Select all
matrix(!i,2) GHtest1
vector(1) breaks
smpl @all
equation ghc1.ls sy c iy (@trend>!i)
ghc1.makeresid EEC
genr ZZ = EEC
genr DZZ = D(EEC)
uroot(adf, none, info=aic, maxlag=4, save=level!i) ZZ
GHtest1(!i,1) = level!i(3,1)
GHtest1(!i,2) = level!i(2,1)
vector minaic = @cmin(GHtest1)
vector eqn_minaic = @cimin(GHtest1)
Warmest regards,
tcfoon
