Gregory-Hansen cointegration test
tcfoon
Postby tcfoon » Sun May 31, 2009 5:07 pm
Dear trubador and others Eviews programming expert,
With the help from Trubador, I have written the following sets of codes for Gregory and Hansen (1996) cointegration test. Unfortunately, both codes seem to be correct but I am not sure why the results is vary between the programme used. In term of result, I think the second set of code should be correct, while the first set of code will produce more easy and presentable result. Therefore, I attempt to request the Eviews programming expert to improve the first codes. Of course, I would also appreciate that if the Eviews programming expert willing to write a more shorter and presentable code for the Gregory-Hansen test.
The Gregory-Hansen programming code were reported as below:
First set of GH code:
!trim = 0.15 'Trimming parameter !t_min = 1000 !min_aic = 1000 vector(1) breaks for !i = @round(@obs(sy)*!trim) to @round(@obs(sy)*(1-!trim)) smpl @all equation temp.ls SY c IY (@trend>!i) temp.makeresid EEC genr ZZ = EEC genr DZZ = D(EEC) for !lag = 0 to 4 if !lag = 0 then equation temp.ls DZZ ZZ(-1) else equation temp.ls DZZ ZZ(-1) DZZ(-1 TO -!lag) endif if temp.@aic < !min_aic then !best_lag = !lag !min_aic = temp.@aic if temp.@tstats(1) < !t_min then !t_min = temp.@tstats(1) breaks(1) = !i+2 'Identified first break point. series DU1 = @trend> !i series DT1 = DU1*(@trend-!i) if !best_lag = 0 then equation GH.ls DZZ ZZ(-1) else equation GH.ls DZZ ZZ(-1) DZZ(-1 TO -!best_lag) 'Selected equation endif endif endif next next delete temp
Second set of code:
!trim = 0.15 'Trimming parameter for !i = @round(@obs(sy)*!trim) to @round(@obs(sy)*(1-!trim)) matrix(!i,2) GHtest1 vector(1) breaks smpl @all equation ghc1.ls sy c iy (@trend>!i) ghc1.makeresid EEC genr ZZ = EEC genr DZZ = D(EEC) uroot(adf, none, info=aic, maxlag=4, save=level!i) ZZ GHtest1(!i,1) = level!i(3,1) GHtest1(!i,2) = level!i(2,1) next vector minaic = @cmin(GHtest1) vector eqn_minaic = @cimin(GHtest1)
Thank you in advance,
Warmest regards,
tcfoon
trubador
Did you use forum search?
Re: Gregory-Hansen cointegration test
Postby trubador » Mon Jun 01, 2009 2:19 am
For the first code you should change the following line:
... breaks(1) = !i+3 'Identified first break point. ...
For the second code:
... vector eqn_minaic = @cimin(GHtest1) eqn_minaic(1) = eqn_minaic(1)+3 ...
However, in the second code, selection procedure based on ADF unit root test fails to correctly pinpoint the location of the structural break with plus or minus one observation.
tcfoon
Postby tcfoon » Mon Jun 01, 2009 3:13 am
Dear Trubador,
Thank you for correcting the codes. I wonder why the we have to use break(1) = !i+3 instead of break(1) = !i+2 for the first code.
My concern is that why both tests results and also the identify breaks date vary so much. Is there anything wrong?? For example, the first code noted that the break point should be 15 after adjusted to !i+3, but the second code suggest that the break date should be 39 after adjusted to +3.
Here, I also attached the workfile for you to have a look.
Thank you,
Regards,
CF Tang
GH.WF1
(8.62 KiB) Downloaded 1250 times
trubador
Postby trubador » Mon Jun 01, 2009 5:01 am
Plus one is due to trend variable, since it begins with zero. Plus two is due to "greater than" inequality operator. And plus three is due to first difference of the residual series.
First code does not take into account the information from the initial equation that you first obtain residuals, which creates the major source of difference I believe. Your code ignores the initial setting and does an exhaustive search only on the secondary equations that first difference of the residuals from the first equations are the dependent variables. In the second code, however, you apply unit root tests to the level of residuals. Therefore, you should expect the second code to perform better in most cases.
rnt2008
Postby rnt2008 » Wed Jun 03, 2009 7:24 am
To QMS people, why not writing a structured routine to be inserted in the program repository using the pieces of code herein posted?
Postby EViews Gareth » Wed Jun 03, 2009 8:11 am
I am sure that, and would be pleased if, once Trubador and TCFoon have got the code to their satisfaction, they will put it in the program repository.
jjaa
Postby jjaa » Wed Oct 06, 2010 6:00 pm
i have a problem, when i run the test and define the series IY and SY, it appears a window thats says, insufficient number of observations, and i am working with more than 100 observations.
Thank you
mdshahid
Postby mdshahid » Mon Jul 18, 2011 2:32 am
Dear Trubador and Gereth
I am using EViews for last few years. I am a PhD student in Australia. Recently, I tried to run the Gregory and Hansen (G-H) cointegration test program developed by Trubador and TCFoon. I could run the program successfully. I really appreciate your help.
Now, the program you developled only gives result for constend and trend (model 3). I need to see the G-H conintegration test results only for constant (C) and without trend. Also I want to get the G-H conintegration test result for constant and regime shift (C/S). Could you please kindly know me how I can change the codes to get the results for C and C/S.
Thanks for your help
Shahid
kakali
Postby kakali » Wed Apr 25, 2012 2:37 am
Dear trubador, tcfoon and others Eviews programming expert,
I am new to Eviews programming, I have tried to run the attached code and found the following error
Type Mismatch at Argument 2 in CALL GREGHANSEN(Y, X, 3, "AIC", 6)
Data file is also attached.
Your help will be highliy appreciated.
Thanks,
-Kakali.
gold.xls
(18.5 KiB) Downloaded 1120 times
ghtest.prg
(4.8 KiB) Downloaded 1297 times
kakali
Postby kakali » Wed Apr 25, 2012 2:44 am
Dear trubador , tcfoon, wolly77,
I have been trying to run the following code, which returns the error
!NINDEP is not defined or an illegal command in !NINDEP=G.@COUNT. Data and Program files are attached.
I am new to E-views programming. I appreciate your help.
Thanks so much!
-Kakali.
my_workfile.WF1
(26.47 KiB) Downloaded 915 times
prog_gh_prova.prg
(5.41 KiB) Downloaded 1159 times
trubador
Postby trubador » Wed Apr 25, 2012 12:38 pm
You should not change the arguments in the subroutine. The relevant parts for your analysis are as follows:
open .\my_workfile group independents independents.add ylyt stnw nstnw fedf_n call greghansen(pce,independents,3,"aic",8)
kakali
Postby kakali » Thu Apr 26, 2012 4:59 am
Thanks very much Trubador.
It ran now. I will now run on my data and certainly touchbase with you if there is any problem.
Thanks a lot !! :D
-Kakali.
kakali
Postby kakali » Mon Apr 30, 2012 4:06 am
Dear Trubador,
Please advise if the values received for Za test...needs to be multiplied by 100. The test statistics I have obtained seem to be to low to be true, also does not seem to be correct as the formula of the test statistic shows that it has a multiplier of n (sample size), so it is unlikely that the values will be <1.
Also, the crtical values that Bruce obtained has three values corresponding to 3 models, however, while running the code I get same results for all three models.
I attach here the test results.
Please advise?
Thanking you for your help in advance.
oilsex.WF1
(95.45 KiB) Downloaded 816 times
ghtestex.prg
(5.46 KiB) Downloaded 1469 times
GHTEST Results.xlsx
(12.18 KiB) Downloaded 1244 times
kakali
Postby kakali » Wed May 02, 2012 12:13 am
Dear Trubador,
Can you please advise on the above queries?
Appreciate your quick response.
Regards,
-Kakali.
sherrihan
Postby sherrihan » Fri Jun 01, 2012 9:05 am
Dear Trubador
I would like to use the above code to test for cointegration between six countries in the presence of a structural break. Can you please help me in updating the main code i.e. extending it to a multivariate case?
Thank you.
Regards,
Sheri
