Dear Eviews - when I use hfetch in Eviews8 the description has disappeared
when I run hfetch(\\...\eudata) j184expp
Under eviews7 in the label view of j184expp the description and displayname were:
Spain: Nat Curr Price Index: Exports of Goods and Services (SWDA, 2005=100)
Under eviews8 i just get the country number 184 for description and displayname
This is a problem because one of the advantages of using eviews and hfetch was i could easily document my series and their definitions
Am using the July 26 2013 build - has it been fixed since?
hope you can help
thank you Mark
Probem with Haver - data description has disappeared
Re: Probem with Haver - data description has disappeared
Unfortunately, we cannot replicate the problem. I would try updating your copy of EViews via help->EViews update.
If that does not fix the problem please send your Haver database file to support@eviews.com.
Hi, I have a similar problem with Hfetch
When I do this:
Open Spain
Fetch [series]
Close Spain
I get the series with the metadata from the haver data base 'Spain'
But when I do this:
hfetch(h:\dlx\spain) [Series]
I get the series but not the meta data.
That does seem a bit odd and irritating. Can you help?
I am on Eviews 10+ May 15 2018 Build
J
When I do this:
Open Spain
Fetch [series]
Close Spain
But when I do this:
J
hfetch is very outdated and no longer supported - is there a reason you can't use fetch?
No, I hadn't realised I could specify the haver data base name in fetch command.
J
J
Users browsing this forum: No registered users and 16 guests
