Importing trade data with special date format
Posted: Sun Oct 20, 2013 8:19 am
by neophytosk
Hello
Do you have any suugestions on how to import a financial series dataset with the following dat structure:
16JAN2012:03:43:42
I tried to import as unstructured and then convert the date variables as below, but i recieve an error:
series datetime = @dateval(@str(lastmodificationdate, "f11.0"),"DDMMYYYYHH:MI:SS")
I have attached a sample in excel
Any support is much appreciated
Neo
Re: Importing trade data with special date format
Posted: Sun Oct 20, 2013 8:25 am
If I open that file in EViews 8, EViews automatically recognises the "LastModificationDate" column as a date/time stamp.
You cannot structure the workfile by that series though, since it does not contain unique values.
Posted: Sun Oct 20, 2013 11:30 am
by neophytosk
I am using eviews 7 , is there a way to open the file as you do in v.8?
Also what do you mean by unique values? That some observations occur in the same time?
Thnx
Neo
Posted: Sun Oct 20, 2013 11:41 am
Yes, some observations occur at the same time, so you cannot use time as an observation identifier.
Posted: Sun Oct 20, 2013 1:34 pm
by neophytosk
thnx for the comments.
I imported the data as suggested and use "deal_id" as the identifier (see updated attached sample file) but I still would like to change "lastmodificationdate" to a readable eviews date format as I would like to create a new file with frequency compounding (where I sum up variables for example every 10 minute interval (based on the new date variable)
Any suggestions on how to update the date series?
BR,Neo
Posted: Sun Oct 20, 2013 1:35 pm
Post your EViews file.
Posted: Sun Oct 20, 2013 1:56 pm
by neophytosk
here is a sample, the original file has 1mln observations so it is too bigto upload
Posted: Sun Oct 20, 2013 3:37 pm
In that file lastmodificationdate is already a date format.
Posted: Mon Oct 21, 2013 12:44 am
by neophytosk
perfect,
can i use it now to compund the frequencies e.g at 10 minutes intervals?
if yes how can I do this in eviews?
Thnx
Neo
Posted: Mon Oct 21, 2013 7:43 am
Create a new page at the frequency you want. Then copy the date over from your existing page to the new page, performing general-match merge frequency conversion. See the User Guide for more details.
