COM Registration
elias41
COM Registration
Postby elias41 » Fri Oct 18, 2013 5:32 am
Currently, I try to register EViews COM with typing the following in the command window:
C: \Program Files\EViews 8\Eviews8_x64.exe /register
Unfortunatelly, I get the error message: "C: is not defined or is an illegal command."
Where's my mistake :?:
Regards
Re: COM Registration
Postby EViews Steve » Fri Oct 18, 2013 8:00 am
Ok, I think you're trying to run a DOS command inside an EViews command window.
You need to open a DOS command window (go to the Start button, type in CMD in the Run text box and hit enter).
Once you're in the DOS window, first go to the EViews 8 subdirectory. Once there, type in
Alternatively, you can just run EViews, then type in the EViews command REGCOMPONENTS and hit enter. When you see the dialog come up, just the click "Yes (All)" button to re-register everything.
elias41
Postby elias41 » Mon Oct 21, 2013 1:28 am
That works fine, many thanks!
