PANEL DATA IMPORTING
lnp3
Postby lnp3 » Mon Oct 14, 2013 6:08 pm
Dear forum,
I really need your help!! I am trying to make sure that I have imported panel data into Eviews 7 correctly.
Can you please check my file? I am attaching both Excel and Eviews 7 files. This time, my unit of observation is "countries" rather than "banks".
however, It is strange that there are 644 observations. It should be more than that. There are 86 variables, 7 countries, 22 years. Where is 28 coming from?
I followed Eviews Gareth's suggestions:
After importing, he told me to do this. I have replaced "banks" with "countries"
Proc->Reshape->Unstack
Then enter "countries" in the first box, enter "Years" in the second box, and then change the third box so that it is "?*" rather than "*?".
This will create a new page where each series starts with either "equity.." or "netinc...".
From that new page do this:
Proc->Reshape->Stack
Then enter "gdp?" in the first box and hit ok.
That will create the page you want. The only thing left to do is to structure it as a panel.
Click on Proc->Structure/Resize.
Change the structure type to dated panel
Set the Cross section ID as "VAR01"
Set the date id as "YEAR"
thanks a lot.
:?: :roll:
LA_panel_all.wf1
(472.25 KiB) Downloaded 529 times
test.xlsx
(242.99 KiB) Downloaded 683 times
Re: PANEL DATA IMPORTING
Postby EViews Gareth » Mon Oct 14, 2013 8:01 pm
Don't have EV7 on me, but the following seems to work ok in EV8:
open test.xlsx pagestack arg bra chl col mex per ven pageunstack countries var01 years delete countries var02 rename var02con con_ rename var02* * pagestruct @date(years) var01
lnp3
Postby lnp3 » Tue Oct 15, 2013 5:30 am
Sorry, Eviews Gareth. I meant to say Eviews 8. I have Eviews 8, not Eviews 7.
So I will use your command from below.
Your "interactive" guidelines worked with "banks" before, I don't know why they seem different with "countries" this time..
Can you show me like this again?
http://www.eviews.com/Forum_support/pan ... ucture.htm
I really appreciate your help.
lnp3
Postby lnp3 » Tue Oct 15, 2013 6:04 am
Sorry Eviews Gareth, I could not do it..
1) where you say: pagestack arg bra chl col mex per ven (in this page, do I have to change "*?" to "?*" )
2) there is nothing like var02con con_
I am confused. Can you show me like this interactive again? Like you did before. I am attaching the file again.
Always grateful for your help.
best,
test.xlsx
(242.99 KiB) Downloaded 584 times
lnp3
Postby lnp3 » Tue Oct 15, 2013 6:07 am
sorry for posting again. I meant if you could show like this.. the link was wrong in my previous post.
thanks a lot.
lnp3
Postby EViews Gareth » Tue Oct 15, 2013 7:56 am
Just run the commands I gave one at a time in the EViews command line.
lnp3
Postby lnp3 » Wed Oct 16, 2013 6:14 am
yes, it works. thank you!
lnp3
Postby lnp3 » Wed Oct 16, 2013 6:46 am
hello Eviews Gareth, just double checking..
I opened test.xlsx as usual ("open foreign data as workfile" from the menu) and ran your commands one at a time..
I did not write "open test xlsx" in the command line.
I ran the rest one at a time..
open test.xlsx
rename var02* *
please correct me if I am wrong.
thanks!
lnp3
:roll: :lol:
Postby EViews Gareth » Wed Oct 16, 2013 6:49 am
Yes.
lnp3
Postby lnp3 » Thu Oct 17, 2013 3:32 pm
thanks
