Display save size
wjgatt
Display save size
Postby wjgatt » Mon Sep 23, 2013 4:01 am
I'm trying to export a table to pdf format (which works), however if I try to resize the table to a lower size, the command is not being accepted.
I quote the command and reference guide for Eviews 8, page 55:
"Alternately, the command:
tab1.save(r=B2:C10, t=html, s=.5) c:\data\MyTab2
saves the specified cells in TAB1 as an HTML file to “Mytab2.HTM” in the directory
“c:\data”. The table is saved at half of the display size."
I am getting an error message "Invalid save option" when I set s to a value, say 0.8. This happens irrespective of the type of output I choose for the table, or whether or not I write s=0.8 or s=.8, or any value for that matter. I know this can be done manually from the 'Proc' dropdown menu, but I want to program it.
Many thanks
W
Re: Display save size
Postby EViews Jason » Mon Sep 23, 2013 8:01 am
I would make sure your copy of EViews is up to date via help->EViews update.
Secondly the example you mentioned is incorrect (the docs need to be corrected). It should read
tab1.save(r=B2:C10, t=html, s=50) mytable
The 'save' value should in be whole percent.
When I use type in the command as listed, I get the error "Scale percent must be >5% and ....". It's not clear why you are receiving "Invalid save option". If you can, please post a screenshot of the error.
wjgatt
Postby wjgatt » Tue Oct 08, 2013 2:36 am
Thanks for your reply.
The build date in March 28 2013.
See the attached screenshot for the code and the error notification.
W
Postby EViews Gareth » Tue Oct 08, 2013 5:13 am
Please update to the latest version.
wjgatt
Postby wjgatt » Tue Oct 08, 2013 6:46 am
Just found the update logs; apparently the bug was solved in the July 2013 patch.
W
