Is there a way to change the default thousand separator in tables?
It is always formatted to "," although in my regional settings it is set to " ".
Thousand separator
Re: Thousand separator
Not quite sure I follow. To which regional settings are you referring?
"Region and Language" settings in Windows 7 control panel.
EViews has its own option, under Options->General Options->Spreadsheets (If my memory serves correctly)
Yes, there is a switch for "thousand separator" but I can't see an option to format it. I would like to change it from comma "," to space " ". The same as my system default "thousand separator" which is space " ".
Ah, sorry, I thought you wanted to change it to a period, not a space. We don't support spaces.
It would be great if you could add support for space separators for thousands. At least in tables.
Thanks,
Erik
Thanks,
Erik
