visual bug
rousing
visual bug
Postby rousing » Tue Sep 17, 2013 8:36 am
We have detected at visual bug for many eviews sheets with many series, the following code and screenshots can hopefully exemplify the problem for you to replicate.
step 1: run the code
step 2: manually enlarge the size of the workfile (see picture 01)
step 3: pull the slide bar to the right (see picture 02)
step 4: goto a different application and return to eviews (see picture 03)
As a result only a few of the sheets are visually identifiable even though there should be plenty of room to display them
Thank you in advance for your assistance.
Best regards
Rasmus Rousing
wfcreate(wf=test, page=test) m 1980m01 2015m12 for !i=1 to 15 %sheetname="test"+@str(!i) pagecreate(page={%sheetname}) m 1980m01 2015m12 for !j=1 to 1000 %seriesname="series"+@str(!j) series {%seriesname} next next
rousing
Re: visual bug
Postby rousing » Tue Sep 17, 2013 8:37 am
The problem is detected in Eviews 8 with the latest patch
Re: visual bug
Postby EViews Glenn » Tue Sep 17, 2013 11:43 am
Thanks for the program. It helps. We'll have someone look into this.
Re: visual bug
Postby EViews Jason » Thu Sep 19, 2013 11:56 am
