Identify a missing date importing from Excel
shm83
Postby shm83 » Fri Sep 13, 2013 3:27 am
Good morning:
If we are programing within a Dated WF (Daily - 5 day week), in which I know the Start Date and the End Date, and I am importing 2 series from an Excel file (the first column is the date, and the second a value), how can I make Eviews identify a missing date from the Excel, leaving the correspondent value as NA??
I do not know if this is possible :s
Thank you
Re: Identify a missing date importing from Excel
Postby EViews Gareth » Fri Sep 13, 2013 7:59 am
Probably the easiest way is to create the daily page first, then import the data into it. EViews will fill in the missings with NAs.
shm83
Postby shm83 » Mon Sep 16, 2013 1:06 am
I have tried with this:
%path = @runpath cd %path ' Open daily (Mon-Fri) wf wfcreate(wf=dailydata) D5 01/01/2013 12/30/2013 read(a2, s= sheet1) InputSeries.xls 3
My source Excel has 3 columns, the first one with the dates, and the 2nd and 3rd with values.
If there is a date missing, for example the 8th of Jan, in the Excel file, Eviews places the excel original 9th of Jan value in the 8th of Jan (in Eviews) row instead of filling that date with an NA. Could it be the date format I use in the Excel file (dd/mm/yyyy) the problem?
I attach the example excel so It can be useful to understand my issue.
Thanks once more.
InputSeries.xls
(36 KiB) Downloaded 454 times
shm83
Postby shm83 » Mon Sep 16, 2013 7:11 am
If I import it "manually" from the WF window it works, but i cannot make it through code (as a part of a program) :|
Postby EViews Gareth » Mon Sep 16, 2013 7:30 am
Use import, not read.
shm83
Postby shm83 » Mon Sep 16, 2013 8:01 am
Thank you, I was also trying with import (type=excel) and other arguments, and all gave me problems.
Again, the easier, the better. Just a simple
import InputSeries.xls
does it.
