Hello Is there any command that prints the cross section and/or period fixed effects in eviews? I am trying to save them into a separate matrix but I also need the crossid of each one of the effects. Since the @effects command does not provide it is there any other way to do it (using a view command along with the freeze command for example)? Thanks in advance.
Best
Koubas
Cross section and period Fixed effects view command
Dave_the_Forecaster
Re: Cross section and period Fixed effects view command
I have had to do this occasionally. Could be made so much simpler if only we were able to freeze the equation view.
Anyway, try this (just change %eq and %cx_id):
%eq="equation01" 'equation name
%cx_id="region" 'cross-section identifier series
smpl @all
series cxid=@crossid
%eq_smpl={%eq}.@smpl
!ncross={%eq}.@ncross
smpl %eq_smpl
freeze(mode=overwrite, mytab) cxid.statby open_qtr
%cell_1_1 = mytab(1,1)
while @eqna(%cell_1_1, @upper(%cx_id) )=0
mytab.deleterow(1) 1
wend
!ncross = live_model.@ncross
matrix(!ncross, 2) effects
for !i=1 to !ncross
effects(!i, 1) = @val(mytab(!i, 2))
effects(!i, 2) = live_model.@effects(!i)
smpl @all
delete mytab cxid-
For some reason we don't have the effects view documented in the manual. Our apologies. I'll see that it gets put in...
Try
Try
freeze(mycx) eq1.effects
freeze(mytime) eq1.effects(period)Re: Cross section and period Fixed effects view command
Thank you both!!
